8th gen si
Old Apr 3, 2023 | 12:14 AM
jdmcali's Avatar
Default 8th gen si
Crank No Start.
Replaced fuel pump (Tested both old n new. They work)
Replaced crankshaft n both camshaft sensors
Replaced fuel pump relay
Fuses look good like new
New battery
All the fuses in the hood fuse box gets power
Under dash fuse box gets power but I dont think the relays do
Old Apr 3, 2023 | 12:16 AM
jdmcali's Avatar
Also, apparently no spark when cranking
N fuel pump wont prime
Old Apr 3, 2023 | 08:39 AM
So why not try some testing? Did you test fuel pressure?
Looking at fuses is useless. This way of testing works well and fast. Do a complete fuse block in less than a minute.
Old Apr 4, 2023 | 08:27 PM
jdmcali's Avatar
Nah. Didnt test for fuel pressure since no fuel pump prime. N for the fuse testing, I just used a test light instead of my multimeter for volt, but I’ll do so right now. Thx
Old Apr 4, 2023 | 08:50 PM
Test light works fine.
Old Apr 4, 2023 | 10:25 PM
jdmcali's Avatar
Yea. All fuses in fuse box under hood gets power except oil level fuse but thats prolly nothing. But when I was testing the pgm fi 1 relay. 2 pins get power, 1 pin clicks, then last pin doesnt get power or click
Old Apr 5, 2023 | 08:59 AM
I don't have any diagrams for that or I could help you out.
Old Apr 8, 2023 | 09:48 PM
jdmcali's Avatar
Hey. If I wanted. Can I change the ecu I think thats the problem cuz all this happened after unplugging it
Jacob skaggs
May 28, 2021 07:43 AM
Christine513
Mar 7, 2016 07:48 PM
mango02
Mar 16, 2012 10:00 AM
mango02
Aug 18, 2011 11:10 AM
rpankau
Jan 6, 2007 03:57 PM
