90' honda civic si coolant reservoir
Old Feb 4, 2009 | 07:42 PM
civicivic90's Avatar
Default 90' honda civic si coolant reservoir
hello honda forum
i have a 1990 honda civic si and my coolant reservoir doesnt refill my radiator, i have put in a new rad, replaced the top and bottom rad hoses, put a new thermostat in and it still wouldnt refill my rad. i tried taking off the reservoir hose and blowing in it and there is no clog or anything in it..... it would be great if you could help me out. thnx
civicivic90
Old Feb 5, 2009 | 10:11 PM
josh2113's Avatar
Member
Exclamation
I hope you are not trying to fill your radiator by filling the reservoir, because you will be there all day. If you want to fill your radiator and have no air in the system get a 12mm socket and a ratchet you will notice where the Upper rad hose hooks up on the engine there is a bleed screw. Open that up. Then fill your radiator with coolant and water 50/50 mix of course until it comes out of the bleed screw. Close the bleed screw put your cap back on fill the the reservoir to the appropriate mark. You are done....if you don't get the air out of the system your car will idle up and down when it gets warmed up its important to use that bleed screw.
Two Eagle
May 15, 2013 09:47 AM
william gray
Oct 18, 2009 02:04 AM
scott1ct
May 21, 2007 11:22 AM
kesmith
Dec 14, 2006 07:25 PM
wingnut84
Oct 16, 2006 11:19 PM
