91 Civic won't start when Hot outside
Old May 31, 2011 | 12:29 PM
Jeffvk's Avatar
Default 91 Civic won't start when Hot outside
Here's a puzzle. My 91 Civic starts every time, all winter long, or if in the shade in the summer, or garage etc. BUT if it sits out in the sun for awhile and is hot, it won't start. When you turn the key on, the fuel pump should run for 5 sec. then turn off, but when it's hot, that inital 5 sec doesn't happen. If you keep trying it, eventually, it will work and start. We've replaced the fuel pump relay and the fuel pump, but it's still a problem.
Any other ideas?
Old Jun 1, 2011 | 02:28 AM
welcome to the forum. Check the main relay, or the distributor
Old Jun 1, 2011 | 09:17 AM
Jason Smith's Avatar
Is there any problem while driving in hot conditions? I mean, say, you start your car under normal temperature and then take the vehicle out in hot sunny weather, do you sense any change then?
Old Jun 4, 2011 | 11:03 AM
Jeffvk's Avatar
No, there's no problem driving it on a hot day, once it starts, it runs fine.
Old Oct 20, 2011 | 10:28 AM
Jeffvk's Avatar
Default Mystery solved
After many hits and misses, it turns out this problem was simply the gas cap. The one that was on it was not factory and it didn't allow the tank to vent. When the car got warm and wouldn't start, if you'd open the gas tank, it'd start right up. A new venting gas cap and the problem seems to be solved.
Old Oct 21, 2011 | 09:50 AM
Glad you found out what it was ,to bad it cost you a fuel pump and relay.Some time it's the simple things that cause the most problems.
Chris Skoglun
Jun 27, 2016 06:46 PM
swany420
Apr 26, 2014 02:38 AM
89accordguy
Aug 18, 2011 06:41 PM
tommytahoe
Jul 31, 2006 04:10 AM
muppas
Jul 24, 2006 09:48 PM
