94 civic alternator change
Old Nov 30, 2006 | 11:10 AM
Camel3g GT's Avatar
Default 94 civic alternator change
Any one have a quick guide to changing this bitch. Its in the hardest spot in the world. Im a mitsubishi driver. the honda is my girlfriends any tips on how to work in this small area?
Old Dec 9, 2006 | 11:59 PM
Default RE: 94 civic alternator change
Go to Auto Zone.com, register for free, navigate to product and how to, and it will tell you how to change that thing. tight fit
Old Dec 31, 2006 | 03:33 PM
josh2113's Avatar
Member
Everyone thinks that the altenators in the civics are pain in the _____! Its really not that bad though.
1)Disconect the battery of course this is a no brainer.
2) Jack up the Front driver's side of the car and remove the wheel.
3) Remove plastic wheel well insert if its still there. (now you should have access to the altenator.
4) disconect wires from altenator and remove the bolts holding it in.
(this is the part were some will tell you that you need to remove the axle. This is not true.)
5) push the alt. so it rests between the block and the fire wall.
6) remove the altenator bracket from the block of the motor. (it should be 2-3 bolts holding it to the block)
7) pull the altenator through the small hole it may take a little flipping around but it does fit.
8) re-assemble in the reverse order.
This works on almost all civics 88-2000
taking out the axle is a headache and time consuming.
Hope this helps.
popomama
Nov 22, 2018 08:25 AM
lxhondacivic
Mar 12, 2011 01:55 AM
lucasvilla
Sep 1, 2009 06:16 AM
ricosuave55
May 27, 2009 10:19 PM
Gardensnake
Nov 19, 2006 02:22 PM
