94 civic ex wont fire, ignition coil?
Old Jun 25, 2008 | 09:26 PM
johnu773's Avatar
Default 94 civic ex wont fire, ignition coil?
hi, im new to this forum and even newer to imports. i have a regular(no mods done) 1994 civic ex which will not fire. ive replaced the cap and rotor but still get no spark. ive stuck a wire in the plugwire(from the cap) and stuck it on the frame to try andsee if the distrubutor is throwing spark but got nothing. the distributor does turn when cranking also.
when it died i was in the middle of driving down the street and it just shut off. the power streeing still worked briefly, and NO warning lights came on. i didnt hear or feel anything(no pops, jerkingor vibrations), its as though the car just shut off. it cranks but doesnt attempt to turn over.
ive read a lot of posts with similar problems here being solved with a new ignition coil. does this sound like the same issue here?
any help or suggestions are greatly appreciated.
i thought timing belt, but it looks fine and i would think id still get spark from the distributor.
Old Jun 26, 2008 | 04:22 AM
Default RE: 94 civic ex wont fire, ignition coil?
good possible ing coil. providing the belt did not jump a slot. and welcome to the forum, enjoy your stay.
Old Jun 26, 2008 | 11:31 AM
johnu773's Avatar
thanks for the info. even if the timing belt jumped, wouldn't i still get spark to the wires if i'm cranking the car and the rotor is turning? i have no spark out of any plug wires.
Old Jun 26, 2008 | 10:51 PM
johnu773's Avatar
IT WAS THE IGNITION COIL!!! hasnt run in 2.5 years and fired right up! runs a lil rough(old gas im sure) so im gonna change all fluids and do a tune up!Thanks again!!!!
matimar30
Oct 12, 2009 02:55 PM
jthtrey
May 25, 2009 06:44 PM
semkruse
Jan 5, 2009 04:15 PM
rizzob
Jun 21, 2007 06:58 AM
fixdupaccord
Oct 24, 2006 07:07 PM
