Auto transmission problem
Old Feb 13, 2009 | 06:39 AM
nirlay's Avatar
Default Auto transmission problem
My Honda Civic , auto transmission, is having some transmission problems. When I am starting to move from zero speed, pressing the gas, it is reving up, making a whoosh sound and it moves very slowly. It also feels that it is slipping the gear. The symptom is less when I am starting the car in low gear. Once it reaches certain speed, it runs smooth. It is only when you start. On uphill slopes, the problem is severe. My engine light was on. The Autozone diag tool said that the input shaft speed sensor is bad.
Any idea on what is wrong ?
thanks
Old Feb 14, 2009 | 11:55 PM
josh2113's Avatar
Member
Check your transmission fluid. Top off if necessary. You may even want to consider having it flushed out with fresh transmission fluid as well. If that doesn't solve your problem you may want to try replacing that sensor just because its that last thing before we say get a new transmission.
jackraider
Jun 2, 2015 11:46 AM
MoonyJohn
May 26, 2015 01:26 AM
B0SSDONMO3
Aug 1, 2009 03:51 AM
bfs117
Mar 8, 2009 09:18 AM
mrag
Nov 20, 2006 05:40 PM
