b20 help please
Old Nov 15, 2013 | 03:19 AM
makapayomo's Avatar
Default b20 help please
Im new here but i have a b20 z2 motor in a 91 integra and my timingbelt broke when i was going uo a hill took it to the shop and they told me i have bent valves in 1 cylinder so instead of changing the valves i baught another head witch is a p75 head and bolted it up to the block i set the timing and it wont start advanced the timing and it still wont start so i ran a compression test and 1&2 cylinders have no compression #3 cylinder has around 145 compression and #4 cylinder has like 85-95 compression could it be that the head i bought the valves are sticky or no good please help or is my timing completly off to were it has no compression please help thanks
Old Nov 15, 2013 | 07:38 AM
welcome to the forum. When you did your compression check, you should have heard air leaking from the intake or the exhaust side. also if it were 1&2 the head gasket could be leaking into each other. or wrong headgasket for different head to block.
White Hatch
Aug 17, 2010 11:30 PM
47b20
Mar 30, 2010 09:50 PM
boostedintegra
Oct 21, 2008 02:10 PM
civet97
Sep 3, 2007 12:44 PM
civet97
Jul 28, 2007 03:45 PM
