Car fails to crank
Old Jun 6, 2023 | 11:21 AM
89dx's Avatar
Default ‘89 civic fails to crank
Hey guys,
I have a 89 civic DX. I have replaced the starter, alternator, and a new battery within the past month and a half. I am now having problems cranking the car. Sometimes it will fire right up and other times it will only make a clicking noise under the dash. The car will crank if you put cables on it but not with a jump box. Any thoughts on what’s wrong? Any help would be greatly appreciated.
Old Jun 6, 2023 | 01:30 PM
Ignition switch?
Old Jun 6, 2023 | 01:32 PM
89dx's Avatar
Ignition switch?
Thank you, that had crossed my mind. But why would it crank with jumper cables if it was the ignition switch?
Old Jun 6, 2023 | 01:33 PM
Nothing. That tells me the cables are not attached correctly. Need to clean and tighten.
Old Jun 6, 2023 | 01:36 PM
89dx's Avatar
Exactly, yes. Battery posts are both cleaned and tightened but the issue is not resolved.
Old Jun 6, 2023 | 02:56 PM
Is the battery fully charged?
Old Jun 6, 2023 | 03:02 PM
89dx's Avatar
yes, brand new batter (bought within 2 weeks) and a volt meter shows it’s fully charged.
Old Jun 6, 2023 | 05:38 PM
How many volts as it cranks? I think you have a weak battery.
Old Jun 7, 2023 | 07:15 PM
might also check all the ground wires/strap, take off the clean scrap and reinstall for good contact.
Old Jun 11, 2023 | 04:35 PM
  #10
89dx's Avatar
thank you both for your help. I have come to the conclusion it is a ground issue. I am working on cleaning the thermostat ground now because it was very dirty/corroded. This ground has to do with grounding the main relay if I’m not mistaken which is the clicking noise I’ve been hearing under my dash when trying to start the car. I’ll update when I have an update. Thank y’all again.
Supermommy2007
Apr 5, 2021 07:21 PM
stateship2
Nov 22, 2018 08:15 AM
chigglebits
Nov 1, 2018 06:29 PM
tobie coker
May 14, 2011 03:43 AM
Neyne
Mar 23, 2008 09:20 PM
