Please Help.. 07 Honda Civic
Old Nov 18, 2018 | 11:10 AM
stateship2's Avatar
Default Please Help.. 07 Honda Civic
Brought the Civic to the store and when I tried to crank it when I left, all I got was a click. Battery was good, voltage good, alternator good.. troubleshooting brought the problem to the starter. I replaced the starter but now when I try to start the car, nothing really happens. Normal illumination light on dash and radio but no warning lights when you turn the key and no click or anything when you try to turn it over. Headlights, fob locking and unlocking, horn and all that works normally. I was thinking some anti theft thing or a fuse somewhere that blew after putting on the new starter but I cannot figure it out. I also cannot put the car into neutral or anything. Before changing the starter I could. I do hear the dinging when you put in the key. This problem only started after changing out the starter. Please help
Old Nov 18, 2018 | 06:13 PM
No crank, no start
So troubleshooting brought you to the starter?
And you replaced the starter
And still there is no crank, no start
So what problem started after replacing the starter?
Sounds like you still have the same problem.
I would suggest cleaning all the cables and terminals .. also the negative or grounding straps.
Then if it is still no crank, no start then check the starter relay
Do a bypass test to see if the control side or load side needs more attention
Old Nov 19, 2018 | 07:57 AM
stateship2's Avatar
Originally Posted by avisitor
No crank, no start
now nothing works. When I put the key in, nothing happens. Lights come on and work. Dash illuminates when I put key in. But no dash warning lights. No sound when turning key to start. Can’t roll windows down when in on position
Old Nov 19, 2018 | 12:38 PM
When nothing works on my vehicle, I usually start looking at the fuses and relays.
Hopefully that will get something working again??
Old Nov 22, 2018 | 08:15 AM
The suggestion of cleaning all terminals and grounds is a good start,look for bad fuses ,to test the starter run a screw driver across the two terminals if it turns over you know it's the relay or switch,good luck.
Hmorgan
Apr 29, 2019 04:03 PM
LX07Pearl
Jun 5, 2013 03:16 PM
Peter mags
Aug 17, 2011 10:29 AM
SOKal
Nov 14, 2006 12:41 AM
SOKal
Nov 9, 2006 08:07 PM
