Please Help.. 07 Honda Civic
Brought the Civic to the store and when I tried to crank it when I left, all I got was a click. Battery was good, voltage good, alternator good.. troubleshooting brought the problem to the starter. I replaced the starter but now when I try to start the car, nothing really happens. Normal illumination light on dash and radio but no warning lights when you turn the key and no click or anything when you try to turn it over. Headlights, fob locking and unlocking, horn and all that works normally. I was thinking some anti theft thing or a fuse somewhere that blew after putting on the new starter but I cannot figure it out. I also cannot put the car into neutral or anything. Before changing the starter I could. I do hear the dinging when you put in the key. This problem only started after changing out the starter. Please help
No crank, no start
So troubleshooting brought you to the starter? And you replaced the starter And still there is no crank, no start So what problem started after replacing the starter? Sounds like you still have the same problem. I would suggest cleaning all the cables and terminals .. also the negative or grounding straps. Then if it is still no crank, no start then check the starter relay Do a bypass test to see if the control side or load side needs more attention |
Originally Posted by avisitor
(Post 31648)
No crank, no start
When nothing works on my vehicle, I usually start looking at the fuses and relays.
Hopefully that will get something working again?? |
The suggestion of cleaning all terminals and grounds is a good start,look for bad fuses ,to test the starter run a screw driver across the two terminals if it turns over you know it's the relay or switch,good luck. |
