Car turns off when put in NEUTRAL!!
Old Sep 16, 2010 | 02:34 PM
bakuryu06's Avatar
Default Car turns off when put in NEUTRAL!!
Hey Guys, Ok so i recently bought a 95 Civic DX with a stock D15B7. The car is in immaculate condition from inside out. The engine is super clean with the exception of one big problem:
While driving the car I often place it in neutral and roll down a hill or what have you, im sure many people do. As I slow down the car shuts off and basically just rolls to a stop. While its turned off I can jump-start the car by putting it in gear and hitting the gas pedal, pretty much a classic rolling start. That is when the check engine light comes on. First thought was fuel injectors and I got them cleaned yet still the same issue. I just had a new timing belt and water pump installed as the car is at 94k. The previous owner had just done a tune-up which included a new distributor and spark-plugs. What should I check first? Distributor? I can't check the ECU for the engine light cuz it is an OBD1 and not an OBD2.
Thanks in advance!!
Old Sep 17, 2010 | 12:49 AM
neilwatson's Avatar
I had never had such problem with my car.I would suggest you to check the distributor and the spark plugs.
Old Sep 17, 2010 | 02:41 AM
check your idle control unit
Crash&Burn
Jan 1, 2013 01:08 AM
keegross
Oct 5, 2011 01:22 PM
walnut777
Apr 5, 2011 09:01 PM
ThunderDiesel08
Aug 12, 2009 12:50 PM
jimbojam
Dec 9, 2007 05:35 PM
