Check brake system, power steering, VSA, ABS
Old Jun 27, 2020 | 04:32 PM
colton1808's Avatar
Exclamation Check brake system, power steering, VSA, ABS
I have a 2013 civc that is displaying check brake system, check power steering, check VSA, check ABS all at once. I have checked the fuses, checked the spark plugs, checked the battery and alternator. What is causing this problem? Car has 70 k on it.
Old Jun 27, 2020 | 04:46 PM
welcome to the forum. did you check he filter in the brake master cylinder, this may cause the light to go on.
Old Jun 27, 2020 | 04:50 PM
colton1808's Avatar
I have not checked the "brake master cylinder filter" I am going to look up how to do that now. Is that just in the reservoir?
Old Jun 27, 2020 | 05:16 PM
yes i believe it is, looks like a cup strainer.
Old Jun 30, 2020 | 05:49 PM
colton1808's Avatar
UPDATE: there is a short in the VSA module, the part is 650 the labor is 150. Had to have a more sophisticated scanner to read the codes than what I had available.
Old Jun 30, 2020 | 11:32 PM
that part sure is expesive. hope it fixes the problem.
David Kidd
Jul 2, 2019 05:53 AM
nikes_ny
May 20, 2007 02:29 AM
nikes_ny
May 2, 2007 12:58 AM
nikes_ny
May 1, 2007 12:59 AM
proff
Feb 12, 2007 01:00 AM
