Civic blower motor
Hi there, new here!
Got this 07 Civic 1.8 petrol, for my son, and we have a problem with the blower motor, makes some noise, think its the bearing. Have checked out on youtube different videos whitch all shows a very easy way to replace it. Only thing is, the blower motor is not located under the dashboard on the right side. Anyone know where its located? thanks! |
Should be there.
Operation CHARM: Car repair manuals for everyone. Home >> Honda >> 2007 >> Civic L4-1.8L >> Repair and Diagnosis >> Heating and Air Conditioning >> Blower Motor >> Locations Blower Motor: Locations104. Under Right Side of Dash:https://charm.li/images/IMP03Q313/asian160/1033215242/pro multis · About Operation CHARM |
Well, that was my point. The motor is not there. When I remove the cover, what I see is just the bottom of the glowboxcompartment. The blowermotor is not located under there. I`ll take photo and try to post it here.
Not a likely candidate for a relocation.
Here is a photo of where all info I get says the blower motor is located.
As we can see, blowermotor is not here, so where is it? is picture to big? https://cimg5.ibsrv.net/gimg/hondafo...39b2b844b.jpeg |
Take the cover panel off.
The panel is off. What you see here is the bottom of glovecompartment, or what you call it, you know the little storageroom to put things.
The panel is not the bottom of the glove box. The glove box drops down and out. The blower motor must be behind the panel or what you call the bottom of the glove box.
Take it apart. It's there. Go get it.
Now I found the connection to the power to the blowermotor, its located at the left side under the right side fottwell towards the center of the dashboard. A bit moore work to replace it then!
Now I have to start removing airvents. Not quite sure if I should bother thou, and just live with the noisy motor! |
