civic wont get into any gear its stick
Old Nov 26, 2011 | 11:48 PM
95civicdx's Avatar
Unhappy civic wont get into any gear its stick
hi i was wondering if anyone knows the answer to my question. I have a 95 Civic DX 5 speed stick. When the cars off it will get in all the gears fine but when it its started it will not go in any gear also when put on reverse it grinds. i pump the clutch bout 10 time when started in neutal then all gears work when started. if i dont start the car and put int into gear then start it the car will move so i know its not the clutch plus it pulls in rpm and mph. pls any answers to help . thx in advance.
Old Dec 20, 2011 | 11:57 AM
dsmidy's Avatar
Hi, I don't know very much but I do know it sounds like your transmission is not getting any tranny fluid or whatever manuel tranny's use. Whatever pumps the fluid to your gear system does not seem to be working. I know that grinding gears don't have fluid. Matbe you should have it serviced. When the pan is pulled you will find metal in it from your gears grinding. The teeth on the gears are being worn away and they have to have teeth on them to work. When you push in the clutch it disengages
the teeth of the gears inside the tranny, you put the car in a gear and release the clutch and the teeth on that gear engages to the teeth on gears inside your gear box(tranny). Your stick will go into gear when your car is off because your drive train is not turning the drives or gears in your gear box. Something like that, like I said I
don't know alot nor the actually terms but I am positive I'm 90% accurate on this post. FLUID, GEAR BOX FLUID!!
Old Dec 21, 2011 | 09:41 AM
welcome to the forum. have you checked the fluid level of the salve cylinder that works the clutch? there is no pan on a standard shift transmission.
Old Dec 21, 2011 | 12:00 PM
That would be my guess.
95civicdx
Dec 7, 2011 08:23 AM
scotty0607
Aug 21, 2010 11:14 AM
94_sol_vtec
Aug 17, 2010 10:09 PM
Bmildner
Jul 14, 2007 09:06 PM
G I Feelgood
Jun 14, 2007 11:36 PM
