clutch issue
Old May 17, 2010 | 08:17 PM
yvette88's Avatar
Thumbs down clutch issue
ok , so i have a 95 teggy ls with a stock b18b1 , i recently replaced the clutch but when i test drove the car , for some odd reason the right front axle popped out , i checked and everything was fine but now car wont start , it only turns but doesn't start , what can it be besides the tranny because i just bought a new one and the starting issue was there before i removed the old one, any tips will be greatly appreciated..
Old May 18, 2010 | 01:19 PM
welcome to the forum. the won't start, check all your plugs, wires, distributor, coil/ignitor, and do you know when the timing belt was last changed? if over 60-112k the belt may have skipped to tooth. check timing. for axle to pop out, the circlip is weak/worn, replace the circlip before reinstallation of the axle. make sure all the suspension system holding the axle in place is good or snug.
stsmaverick
Jun 10, 2015 02:02 PM
aetam91
Dec 17, 2013 07:50 PM
smacneill
Oct 21, 2009 09:59 AM
emmyloulou
Aug 6, 2009 03:29 AM
RC304
Nov 29, 2006 07:21 PM
