Del Sol, need piece for drivers door latch lock. what is it?
Old Feb 25, 2014 | 06:08 PM
VicoDrive's Avatar
Default Del Sol, need piece for drivers door latch lock. what is it?
My interior door handles lock broke from the inside on my Honda Del Sol S, 97.... Now that lock just flaps. I took the entire handle piece off and found that the bar that seems to connect the key lock to the latch lock on the handle, a little white piece that held it in broke. That piece seemed to be what helt the bar into the latch. So basically, I want to know if its possible to buy just that little white piece or do I have to buy the entire handle which seems to run about $60?
The part number for the whole handle seems to be 72160-SR2-A02ZB
I think the part is #15 which is located in the door handle diagram under #22 at http://www.hondapartscheap.com/parts...ning/door-lock. Is this the correct part and am I able to buy just that #15?
Old Feb 25, 2014 | 09:48 PM
lowlife9's Avatar
take a trip to your local pick and pull im sure that year hade the same handle in most hondas.
Old Feb 25, 2014 | 10:48 PM
91haydenSI's Avatar
That white pin was universal for all hondas from the late, late 80's to mid 2000's so if you find a broke down honda in a pick and pull you are good.
If you can't take the one out of the passenger door and go to a hardware store or a lowes. They have something that will fit fine. May not be an OEM replacement but it will work.
Old Feb 25, 2014 | 11:16 PM
VicoDrive's Avatar
I thought about that and already tried. Only one junk yard around here has a del sol. I went there and the handle is there but its already broke just like mine is
Old Feb 25, 2014 | 11:18 PM
VicoDrive's Avatar
pretty universal huh? That should help things a lot! Do you think I could buy that small part directly from Honda?
Old Feb 26, 2014 | 08:18 AM
lowlife9's Avatar
i seriously doubt it.
Old Feb 26, 2014 | 06:04 PM
VicoDrive's Avatar
Went by Honda today amd they were able to order just that part! Only costs about $5 which is a lot for a little piece of plastic but that beats $60 for an entire handle!
Old Feb 28, 2014 | 03:14 PM
VicoDrive's Avatar
Picked up the $5 part today, it worked!
Jschoend
Apr 25, 2019 01:50 PM
VicoDrive
Feb 28, 2014 03:17 PM
snookjohn
Mar 30, 2011 07:41 AM
ajaybali
May 9, 2010 01:05 AM
mergliaa
Jan 10, 2009 02:38 AM
