door panel
their are few screws. should be one by the inner handle with a cap over it. one by the ejector handle, umm one plastic one in the front by your speaker on top and that about it u should be able to pull it out if you pop out the plastic plugs behind the cover..
depending on whether it is auto or manual windows/doors, you should have one in the handle, one by the speaker(or up top by the mirror), and if you have manual windows then you will have to get a flathead screwdriver and pry off the handle far enough to release a clip that holds it on (very tightly i might add), then after that it should just be a matter of the headache of wiggling the thing loose and over the door locks. Good luck man. Just play with it. Civics are pretty easy to take apart.
Kevin Pang
Nov 22, 2011 12:52 PM
