Door Panels
My son has a 2003 Honda Civic coupe and needs to replace the interior door Panels or Linings. Will the front 4 door sedan panels work on this vehicle? What years will work?
You would have to double check this but if I remember correctly the years 2001 to 2005 should work. I don't know about the sedan panels or not but if you go to a junk yard you shouldn't have a problem finding several models that will fit your needs. Like I said defiantly double check me.
welocme to the forum. I do not believe the coup (2dr) and the sedan(4dr) inside panels will fit. 2dr is longer and 4 dr shorter. but coupe to coupe 2001-2005 should fit, and make sure the panel has the same accessory as yours.
