Door Panels
Old Nov 8, 2016 | 02:57 AM
Dickerson888's Avatar
Default Door Panels
My son has a 2003 Honda Civic coupe and needs to replace the interior door Panels or Linings. Will the front 4 door sedan panels work on this vehicle? What years will work?
Old Nov 8, 2016 | 12:46 PM
joyboy390's Avatar
You would have to double check this but if I remember correctly the years 2001 to 2005 should work. I don't know about the sedan panels or not but if you go to a junk yard you shouldn't have a problem finding several models that will fit your needs. Like I said defiantly double check me.
Old Nov 9, 2016 | 02:43 AM
welocme to the forum. I do not believe the coup (2dr) and the sedan(4dr) inside panels will fit. 2dr is longer and 4 dr shorter. but coupe to coupe 2001-2005 should fit, and make sure the panel has the same accessory as yours.
e46323i
Oct 1, 2010 10:56 AM
BlackHat5
Apr 22, 2009 03:57 AM
ein24
Apr 20, 2009 09:38 AM
chippy1020
Jan 17, 2007 12:15 AM
