ecu swap
Old Aug 12, 2009 | 11:00 PM
Lilcastro's Avatar
Default ecu swap
i need to know wat kind of ecu to use for my zc swap engine
Old Aug 13, 2009 | 02:26 AM
welcome to the forum, try to get the ecu from the car the engine came from, or that make and year car the engine is from.
Old Aug 13, 2009 | 09:20 AM
Lilcastro's Avatar
i need to know wat kind of ecu i need for my zc so i can run wat it is suppose to run
Old Aug 15, 2009 | 11:25 PM
Lilcastro's Avatar
would u know wat kind of ecu to use for a zc swap. im trying to get the ecu were the car came from and the make and year the engine is from
Old Aug 15, 2009 | 11:51 PM
91haydenSI's Avatar
welcome to the forums.. the ZC motor has several different variations... ZC ~ Japanese model - Injected, carbed, sohc, dohc, brown valve cover, obd0 and obd1. if you can tell me what kind i can tell you the car it is in stock
Old Aug 16, 2009 | 05:34 PM
Lilcastro's Avatar
i really dont know which one it is, all i know is dat it is a zc
Old Aug 16, 2009 | 11:55 PM
91haydenSI's Avatar
is it a SOHC or DOHC and is it obd1 or obd0???
Old Aug 17, 2009 | 06:19 AM
Lilcastro's Avatar
its Injected not carbed and i its dohc, and i dont know if its a obd1 or a obd0
Old Aug 23, 2009 | 06:56 PM
Lilcastro's Avatar
the head of my engine is a zc but the transmission is a 97 honda civic SOHC vtech.. but my engine is a DOHC non vtech wat kind of ecu should i get for it so it can run good.
Old Aug 23, 2009 | 08:16 PM
  #10
91haydenSI's Avatar
the ecu out of a 1991 honda civic si or crx si will work for that..
