Faultypower Supply (VB Line)
Old Dec 3, 2019 | 01:44 PM
Ambien's Avatar
Default Faultypower Supply (VB Line)
I have a 2014 honda civic EX-L that had a front end collision that has been repaired. However, the airbag did deploy and has also been replaced along with a new SRS module, but I cannot (for the life of me) figure out how to get this code off and I can't find much information about this issue online. If anyone has any insight that could help me that would be much appreciated. Again, the code is "Faultypower Supply (VB line)".
Thank you all, and have a great day!
-Ambien
Old Dec 3, 2019 | 06:11 PM
You will needs a scanner capable of communicating with the SRS system.
Old Dec 4, 2019 | 01:00 AM
welcome to the forum. locate the vb line pin on the module plug. find a test point (10a0 back side of the fuse box. check for voltage. if not power you can run a vb line and secure it to the pin. you may want to get a diagram from pro demand.
Old Feb 22, 2022 | 10:44 PM
ozal's Avatar
-Ambien
hi, sorry for bringing this post alive, but I am having the same issue, I’ve replaced crash sensors, blown airbag, SRS module also replaced with one with no crash data on. Still showing this fault code on scanner.
dud you find the solution? Anyone can help?
Old Feb 23, 2022 | 08:14 PM
Did you try what acmech52 said? What is the actual code?
Honda48
May 27, 2018 10:09 PM
SamsterOX
Oct 17, 2016 01:35 PM
charkev
Feb 26, 2009 08:53 PM
caverspencer
Nov 12, 2007 05:25 PM
KCChiefs9690
Nov 18, 2006 03:09 AM
