Honda del sol questuion
Hello all,
I am the owner of a del sol from 97 with a D16Y8 engine. My issue is: - The ECU is cutting my fuel injection at around 6500 rpm (not at 7200 at it should be) I have checked the ECU errors and I didn't find any error... I have checked all the plugs and hoses from the engine and nothing wrong. Can anybody help me regarding this issue? Thanks. |
How do you know it's the ECU,it could be bad injectors or fuel pump going bad or perhaps a dirty throttle body. Did you reciently install a chip or reprogram the ECU?
the injectors wore cleaned with the throttle body 2 months ago.
And I did not install a chip or a new ECU -- it will be done in the future(:)). Can it be from the quality of the gasoline? LE. Can the Chip-ed ECU damage something in the engine? |
It's possible that you used E-85 or possibly got water in the fuel. A chip will not harm an engine but a cheep one could cause trans. problems.Check this site out ,it may help .http://www.2carpros.com/articles/eng...-or-runs-rough
Changed the gas... Same issue! at around 6800rpm it cuts my fuel.
Should I try oder spark plugs? Or should I look at the distributor? thanks. LE. the chip wont come in the near future (my ecu is OBD 2 :( ) |
you should go to mechanic...........
Problem solved... It is the instrument cluster! The engine reaches the 7200 rpm but the cluster does not show the correct rpm.
Thanks all! |
