Honda del sol questuion
Old Jun 9, 2011 | 07:17 AM
psycho_mishu's Avatar
Default Honda del sol questuion
Hello all,
I am the owner of a del sol from 97 with a D16Y8 engine.
My issue is:
- The ECU is cutting my fuel injection at around 6500 rpm (not at 7200 at it should be)
I have checked the ECU errors and I didn't find any error...
I have checked all the plugs and hoses from the engine and nothing wrong.
Can anybody help me regarding this issue?
Thanks.
Old Jun 10, 2011 | 08:08 AM
How do you know it's the ECU,it could be bad injectors or fuel pump going bad or perhaps a dirty throttle body. Did you reciently install a chip or reprogram the ECU?
Old Jun 10, 2011 | 09:01 AM
the injectors wore cleaned with the throttle body 2 months ago.
And I did not install a chip or a new ECU -- it will be done in the future().
Can it be from the quality of the gasoline?
LE. Can the Chip-ed ECU damage something in the engine?
Old Jun 13, 2011 | 09:41 AM
It's possible that you used E-85 or possibly got water in the fuel. A chip will not harm an engine but a cheep one could cause trans. problems.Check this site out ,it may help .http://www.2carpros.com/articles/eng...-or-runs-rough
Old Jun 24, 2011 | 01:41 AM
Changed the gas... Same issue! at around 6800rpm it cuts my fuel.
Should I try oder spark plugs?
Or should I look at the distributor?
thanks.
LE. the chip wont come in the near future (my ecu is OBD 2 )
Old Jul 17, 2011 | 07:53 PM
jessy's Avatar
you should go to mechanic...........
Old Jul 18, 2011 | 01:50 AM
Problem solved... It is the instrument cluster! The engine reaches the 7200 rpm but the cluster does not show the correct rpm.
Thanks all!
srtdriven7
Mar 25, 2007 11:38 PM
corin
Jan 8, 2007 10:10 PM
ivol
Sep 3, 2006 12:53 PM
Sexililsol
Aug 22, 2006 01:15 PM
ones102envy
Dec 23, 2005 02:43 PM
