ignition keys won't turn
Old Apr 4, 2020 | 03:39 PM
Iceberg9's Avatar
Default ignition keys won't turn
My ignition keys will not turn and start car. I tried different key, turning steering wheel and just jiggling the key endlessly. I assume the tumblers are bad. Any suggestions for a fix so I can drive it for repair? Or even a fix. Any guesses on cost for fixing? Thanks.
Old Apr 4, 2020 | 11:49 PM
Just a wild guess ....
Try putting the gear selector into neutral with the key in the ignition
Then see if you can turn the key?
Can also try spraying lube into ignition lock?
Old Apr 5, 2020 | 04:12 PM
Iceberg9's Avatar
I can't switch gears. I did spray the ignition cylinder and key but didn't help. Thanks for suggestions.
Old Apr 6, 2020 | 12:22 AM
Last resort, get rubber mallet hit key while trying to turn key
Or hit key with mallet and then try turning key
The vibration from hitting the key should release what ever is keeping the key from turning
That is the theory behind this action
Good luck
Old Apr 6, 2020 | 11:40 AM
Iceberg9's Avatar
Thanks for suggestion. I already tried that but didn't work.
Old Apr 6, 2020 | 09:33 PM
Sorry, sounds like you will have to find an auto locksmith??
Or go to Honda dealer??
Old Apr 6, 2020 | 11:04 PM
Iceberg9's Avatar
Go to locksmith but no dealer.
Old Mar 31, 2021 | 09:42 AM
MarkLWiliams's Avatar
Locksmith won't switch gears at all but they can make new keys.
Old Apr 2, 2021 | 06:24 PM
vroomvroom593's Avatar
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->This is definitely a very annoying situation. Most of the times this problem is caused by a sever hit on the steering wheel. However, fixing it is not that expensive.
Old Jun 18, 2021 | 11:49 PM
  #10
intelligenceonline's Avatar
Degreaser
