JDM B16A engine trouble HELP!!!!!!
Old Oct 14, 2009 | 01:11 PM
accorddude14's Avatar
Default JDM B16A engine trouble HELP!!!!!!
got a jdm b16a swap in a 92 civic hatch,
she has a little problem. for about 3 days while going down the road i would hit the gas and the engine would bog down then come back, found that problem and fixed it. now that thats fixed i wake up this morning go to crank the car it fired right up and cut off, did that about 3 times and the 4th just held the gas so it would stay cranked. drove it up the road bout 1/4mile and noticed it was smoking, brought it back home and now its doing the same thing again. im thinking it could be the head gasket or fuel pump/ fuel filter but im not really sure on that. IS THE ANYONE THAT COULD SUGGEST SOMETHING OR THAT MIGHT KNOW THE PROBLEM?
and remember this it not a domestic engine it was shipped from japan its out of a 93-95 civic del sol SIR
Old Nov 3, 2009 | 10:59 AM
strokergsxr600's Avatar
if its blue smoke, you're burning oil, if its white you're burning coolant, i just had the same problem with mine but i was running 14 psi boost, if it is your headgasket, i would upgrade to a greddy 2 mm metal headgasket if you plan on throwing on a turbo, also check your compression to make sure the rings didn't let go, if you have any other questions let me know
captmoto
Sep 4, 2010 10:45 AM
diamindzimage
Jun 18, 2010 02:49 AM
Hoodie951
Apr 9, 2010 10:14 PM
integra-b16a
Oct 17, 2009 01:12 PM
psikyk
Apr 23, 2007 08:47 PM
