loose crankshaft
Old Oct 23, 2009 | 01:37 PM
theboyssi16's Avatar
Default loose crankshaft
so my engine runs but my crank pulley doesnt turn, im thinkin the pulley came loose from the actual crankshaft because i can see the pulley and it looks crooked, so its not turning, any other opinions??
Old Nov 16, 2009 | 10:15 PM
josh2113's Avatar
Member
Some pulleys have rubber dampiners that break free and the only recourse is to replace that pulley. Or your keyway is shot and then you may have other problems.
Old Dec 14, 2009 | 02:39 AM
Aspicle09's Avatar
not enough info provided. your "wobble" may be a misfire, not a loose crankshaft. Watch your crank pulley at the bottom of the motor if you think its coming loose. knocking sounds arent good in engines...internal damage results soon after but again, a knocking in your case may be that its ignition timing is too far advanced. As for the oil leak...how can we judge when we cant even see it? Whether its safe to drive...judging on the question, i would very soon have someone look at it. Cars cant be properly diagnosed over the internet and too many people dont understand that.
Old Dec 18, 2009 | 03:44 PM
enzyday09's Avatar
i have a problem with my zoom ring too.but its not the rubber that is giving me the problem, it is actually the zoom ring.it can now rotate 360.i think there is something loose in the lense.its not even 1 year yet.
tometrajkov
Jul 18, 2011 04:41 PM
1scottm
Apr 2, 2011 03:29 PM
sausage
Sep 13, 2009 06:37 AM
ldynred
Apr 12, 2008 09:21 PM
roddyboy_17
Jul 9, 2007 12:09 AM
