Lost the Audio on Entertainment Center
Old Apr 28, 2022 | 08:58 AM
Cartaphilus's Avatar
Default Lost the Audio on Entertainment Center
I have a 2016 Civic. I have my cell phone paired to the entertainment center with Bluetooth. Everything has been working just fine for years up until a couple of weeks ago, when the audio stopped working. I get no audio from Pulsar, the music app I use, and I get no audio from Google maps, both of which worked just fine until recently. The phone appears to be properly paired, since I see all the track/artist information on the car's screen and I can change tracks using the system's controls. I just don't get any sound. Before I go to the dealer for service, can anyone suggest anything I might have done regarding settings that somehow shut off the sound but left all other functions working?
Old Apr 28, 2022 | 10:10 PM
I have no idea what settings you may have changed. If you don't know who would? It was working fine and you started changing settings?
Old Apr 29, 2022 | 01:25 AM
Turn up the volume control?
Check the wiring to the speakers?
Check fuses to audio?
Old Apr 29, 2022 | 10:40 AM
If it powers on and is working as you say with the exception of the audio output it is not a fuse unless you have a stand alone audio amp. If that is the case you will want to check that fuse. If OK you need to test the audio output.
Old Apr 29, 2022 | 01:40 PM
Sorry if I wasn't clear. I knew what I meant so I assumed everyone else would also. Lesson: don't assume.
I don't know that I changed any settings. So if I did, I wouldn't know which ones I changed. There are lots of buttons and ***** on the entertainment system and I thought it possible that I accidentally changed something. I was hoping that what happened to me might trigger someone else saying "oh, yeah, that happened to me too. Here's what I did."
Old Apr 29, 2022 | 02:06 PM
Were you changing things when it happened?
Koonstheman
Feb 22, 2022 10:15 PM
Frearther
Jul 4, 2019 07:29 PM
