Manual Transmission Intermittent Problem
Old Feb 6, 2018 | 09:08 PM
ykf7b0's Avatar
Default Manual Transmission Intermittent Problem
I'm having an issue with the clutching system connected to the 6 speed manual transmission in my 2012 Civic si. The problem is intermittent and involves getting the transmission into 1st and/or reverse but so far I have been able to engage those gears by killing the engine then restarting. I have changed the trans fluid with Honda brand fluid and have bled the slave cylinder a couple times. After bleeding the slave cylinder the issue seems to resolve but after a few days the problem returns. I see no signs of leakage and the reservoir is always full of fluid. Seems to me the issue is hydraulic but I'm not sure if it is with the slave cylinder, clutch master cylinder, or possibly another component. I would like to hear from those of you who have experienced this or know a thing or two about it and gain some insight for myself on where the problem lies. Thanks!!!
Old Feb 6, 2018 | 10:58 PM
welcome to the forum, possible syncro worn
Old Feb 7, 2018 | 08:58 PM
ykf7b0's Avatar
I think I'm going to start with the easy components before I remove the transmission. I know it's probably not the norm but I think my slave cylinder might be failing without leaking.
Accord2.2dc
Aug 18, 2015 04:24 AM
andy21372
Nov 22, 2013 03:32 AM
Drewcifer
Apr 5, 2011 03:26 PM
kevuofi
Mar 23, 2009 06:23 PM
turkeytrot
May 24, 2007 01:00 PM
