Need help!!!!!!!!!
Old Aug 23, 2009 | 03:49 PM
mears.shaun's Avatar
Default Need help!!!!!!!!!
I added oil to my honda civic ex 1.6 1993 and added a quart to much. Started the car and went to the gas station not even 5 miles up the road and got gas then my car wouldnt start. I tried to spray starter fluid in the throttle body, it kind of started then didnt do anything. I tried to change the battery and jumped it didnt work. I tried swapping around the relays that didnt work. I checked all the fuses and cleaned the ecu. It acts like it wants to turn over. Also I tried to drain out some of the oil from when i put to much in. What am I doing wrong or what should I be doing? Can someone please help?
Old Aug 26, 2009 | 03:05 AM
welcome to the forum. check for spark, check to see if the fuel pump is pumping, or pressure at the fuel rail.
okhozi
Jan 6, 2010 09:10 AM
90civicDX
Apr 1, 2009 09:32 AM
91hondaaccord
Jul 21, 2008 05:15 PM
