NO LOCK for you... 2001 CIVIC COUPE.
Old Mar 30, 2011 | 07:44 PM
mango02's Avatar
Default NO LOCK for you... 2001 CIVIC COUPE.
Electric Locks on drivers door not working, you can lock and unlock with a Key or button. Pulled panel all still hooked up but no action when you press button. How do you trouble shoot door locks or do you just start buying lock motors?
Old Mar 31, 2011 | 02:05 AM
ChaseMark's Avatar
Try programming the keyless entry thing again. Don't know the exact steps you need to follow to do this but I'm sure someone could. Wish you luck!
Old Mar 31, 2011 | 07:06 AM
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed. 7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Old Apr 1, 2011 | 10:44 PM
ChaseMark's Avatar
Hehe....you might want to go over the steps a few times and even do some practice runs....doing each step under 5 seconds must be hard...got to react really fast!!
phrox
Oct 19, 2013 07:59 PM
Julie Landry
Mar 13, 2012 11:26 AM
mango02
Dec 12, 2011 09:15 AM
Scorpio7
Dec 9, 2007 05:06 PM
lovemybluesi
Jan 25, 2007 01:45 AM
