over heating
Old Jun 5, 2006 | 09:03 AM
nkotb's Avatar
Default over heating
sup quick question i have a 93 coupe ex i've replaced the rad. and the thermostate and i'm still runin hot can someone help me out?
Old Jun 19, 2006 | 07:55 AM
Metman2J's Avatar
Default RE: over heating
I would probably check the water pump and/or head gasket next.
Old Jul 18, 2006 | 04:29 PM
Sir^Ducer's Avatar
Is your radiator fan working? I have a similar problem that the radiator fan isn't working, and I was told that the fan switch needs replacing.
Old Jul 18, 2006 | 05:38 PM
BigDan's Avatar
sometimes the aftermarket thermostat wont work right... But then again im relating a problem i had with my mazda to this. haha...
I say check the water! haha
Old Sep 17, 2006 | 01:27 AM
seanyp02's Avatar
Check ur ect (engine coolant temp) sensor...If its bad, it can read hot all the time. Let me know how it works out./
Old Oct 3, 2006 | 06:06 AM
BlackJack's Avatar
gud advise all.
once repaired, i wud advise u to add coolant in ur rad.
Old Sep 10, 2007 | 10:00 PM
chelle26's Avatar
Overheating can be caused by anything that decreases the cooling system’s ability to absorb, transport and dissipate heat, such as a low coolant level, loss of coolant (through internal or external leaks), poor heat conductivity inside the engine because of accumulated deposits in the water jackets, a defective thermostat that doesn’t open, poor airflow through the honda passport radiator, a slipping fan clutch, an inoperative electric cooling fan, a collapsed lower radiator hose, an eroded or loose water pump impeller or even a defective radiator cap.
Old Sep 18, 2007 | 07:22 AM
elflako973's Avatar
Hey sup. You might wanna check if your fan turns on and how long does it stay on. Do u beat it?
Old Nov 6, 2007 | 02:36 PM
importuner99's Avatar
drain the whole coolant system and fill it back up. you have a bubble in your coolant line.
Old Nov 11, 2007 | 07:56 PM
  #10
honda5man's Avatar
hey man check and see if your timing jumped
