Transmission Identification Help
Old May 21, 2020 | 12:04 AM
Jamesalp11's Avatar
Default Transmission Identification Help
Hi, I have this transmission at my shop that came out of a civic apparently, but I’m having trouble identifying if it is a B or D series. I’m no expert with Hondas. There are no visible codes or markings on it unfortunately. Hopefully someone is a pro and can identify it by looks. Thank you!
Old May 21, 2020 | 09:32 PM
Welcome to the forum. Check near the fill plug to see if you can find a casting nbr. With that casting nbr you may be able to ID that trans.
Old May 21, 2020 | 09:48 PM
Jamesalp11's Avatar
Hi. Thanks for the response! The only markings are on the transmission are YSK-3. From my research it seems to be a b series.... but doesn’t tell me what model (I’ll use the spinning and counting method to figure it out). It seems like it’s been repainted so there are no other visible markings. Is anyone able to confirm that YSK-3 means b series?
erik1987civic
Mar 24, 2018 01:05 AM
Nov 22, 2008 08:38 PM
