Water leak under distributor?
Old 08-18-2009 | 01:15 PM
retrolopez8's Avatar
Default Water leak under distributor?
Hey all, i have a question, see if anyone can help me out here.My honda civic dx started leaking water a month back, was from the radiator. replaced it, and all hoses, thermostat check out, but once it heats up it starts to leak below the distributor. only thing i can see that is involved with water under there is the heater hose, but that seems good too. Anyother components that pertain to the cooling that would be belowthe distributor? i sure hope its not the block. it did heat up on me a couple of times before i replaced the radiator and parked it.
Old 08-19-2009 | 12:59 AM
91haydenSI's Avatar
welcome to the forums.. to me it sounds like a head gasket. the only sure way to be able to tell is if there is water in the oil or visa versa.
Old 08-19-2009 | 04:23 AM
if you have a rad pressure tester, you might be able to detect air bubbles around the area of the leak.
Old 08-20-2009 | 04:54 PM
Thanks alot guys. i.ll check into it. head gasket sounds about right though.
knto001
04-15-2022 11:25 AM
donkeysnout
04-12-2007 09:32 AM
Ricardo
12-05-2006 11:59 PM
unclewilco
08-15-2006 09:40 PM
slantill
06-26-2006 03:47 PM
