2001 Honda CRV-Check engine reads-misfire in cyl 3
Autozone did a check engine code readout and it said misfire in cylinder 3. Car runs fine. What can I fix to stop this check engine light from coming on?
Welcome to the forum,the most obvious is change a plug wire or plug itself. Do this little trick crank your engine at night in a very dark place raise the hood and look for sparks coming from the no. three plug wire if you see them there is the culprit.
hokietiger
Feb 11, 2015 03:15 AM
usmc1969
Oct 10, 2013 12:28 AM
