2001 Honda CRV-Check engine reads-misfire in cyl 3
Old Oct 17, 2011 | 02:45 PM
jim cahoe's Avatar
Default 2001 Honda CRV-Check engine reads-misfire in cyl 3
Autozone did a check engine code readout and it said misfire in cylinder 3. Car runs fine. What can I fix to stop this check engine light from coming on?
Old Oct 18, 2011 | 09:33 AM
Welcome to the forum,the most obvious is change a plug wire or plug itself. Do this little trick crank your engine at night in a very dark place raise the hood and look for sparks coming from the no. three plug wire if you see them there is the culprit.
Old Oct 18, 2011 | 07:07 PM
jim cahoe's Avatar
Thanks very much for the suggestion. Is there anything serious that could be wrong or is this most likely the problem.
Old Oct 19, 2011 | 11:45 AM
Other than be annoying and loss of mileage no. Did you find out what it was?
hokietiger
Feb 11, 2015 03:15 AM
usmc1969
Oct 10, 2013 12:28 AM
thunderstrikes
Jul 9, 2013 07:17 PM
cjang
Mar 10, 2009 03:27 PM
tferstl
Jun 9, 2008 06:06 PM
