2011 Honda CRV, can't line up wheel bearing assembly with strut bolts front right si
Old Apr 21, 2022 | 10:23 AM
BIllyblues's Avatar
Default 2011 Honda CRV, can't line up wheel bearing assembly with strut bolts front right si
Old Apr 21, 2022 | 12:44 PM
You need to jack the knuckle up.
Old Apr 21, 2022 | 02:34 PM
Take a picture from further back so I can see it all.
Old Apr 21, 2022 | 03:03 PM
BIllyblues's Avatar
Spoiler
Old Apr 21, 2022 | 04:23 PM
I can't tell what you are struggling with. Raise and lower until it lines up enough to get a bolt in. Once you have one it is easy.
Old Apr 21, 2022 | 04:35 PM
BIllyblues's Avatar
# Ok i have n,tried strut won't move ss the bolt on the upper ball joint is way off ?? Ill try again
thanks for your reply.
Old Apr 22, 2022 | 12:59 AM
Is the upper part of the strut in the correct mounting holes?
Old Apr 22, 2022 | 08:37 AM
BIllyblues's Avatar
yes it is thank you for replying, should i worry about sway bars ?
Old Apr 22, 2022 | 11:53 AM
Your son must have seen what was wrong and fixed it already??
May just needed to be forced into correct position?
Sway bar? If it was not moved then probably not
Old Apr 22, 2022 | 12:27 PM
  #10
The sway bar is connected to the lower control arm. Did you disconnect it? That may be why you are not getting it up in place.
Nkoby97
Jul 5, 2021 10:02 PM
Redbeardpilot03
Dec 30, 2020 07:22 PM
lornoyy
Sep 20, 2019 02:35 AM
Deadpool
Feb 12, 2018 01:02 AM
