-   Honda Forum Help & Suggestion Center (https://hondaforum.com/forum/honda-forum-help-suggestion-center-35/)
-   -   94 accord ex with abs brake issues (https://hondaforum.com/forum/honda-forum-help-suggestion-center-35/94-accord-ex-abs-brake-issues-4357/)
deeprecon1 Aug 12, 2009 11:36 AM
Ok ..so first off, It started with a abs light and a soft pedal and high idle.
Key points
abs light
soft pedal
high idle
So started cheap... master cylinder "brake", then discovered the booster was loosing vacuum. SO I replace it .... a bit of a pain but I got it done.
I then proceeded to bleed the entire system from the rear to the front.
So now.... the abs light goes out and stays out ..
The Problem now the brakes, all of them! are not releasing "locked up"
The only way to get them to release is to bleed the pressure off. Only to have it happen once the brakes are applied again !
Are there some check valves in the abs that could fail? I would think not ....
acmech52 Aug 21, 2009 06:48 AM
welcome to the forum. Did you bleed the modulator
