95 civic gear shift light
Old Jun 21, 2007 | 10:48 AM
help's Avatar
Default 95 civic gear shift light
I need help getting to the lightbulb in my 95 civic gear shift so I can replace it. It has been out for some time and the dealer wants $40.00 to fix.
Old Jul 19, 2007 | 07:00 PM
Dongss's Avatar
Default RE: 95 civic gear shift light
It is only a $5 light bulb, but you may have to remove the center console to get to that bulb.
I am not familiar with the civic but most of the honda's are pretty close.
Remove the upper storage compartment if you have one, remove the rug inside and lossend the screws, then look for screws under the cup holder on the side until you can remove the center console.
The gear shift ring usuals justs pulls up (clips in) tug lightly, if you feel resistance, don't snap it, probably more screws.
Once you get the center console covering off, there is usually a bulb holder on the side of the gear shift, look for the tell tale wires to the bulb.
Just pull out old bulb and replace with new one...Warning, test before putting everything back only to find you brought the only bad "new" bulb.
Good Luck!
Dongss
Old Jul 19, 2007 | 07:04 PM
Dongss's Avatar
Here's a pic from a 1993 accord..
It's a stick shift but the screws are still the same.
Dongss
[IMG]local://3272/676565883263408AA7C5FE75171CB28F.JPG[/IMG]
needhelp718
Nov 19, 2013 08:02 PM
Spyke5544
Sep 18, 2009 06:47 PM
micmoor
Jul 13, 2009 08:53 AM
Katherine001
Jan 8, 2007 03:08 PM
drizzt3434
Jul 7, 2006 07:39 AM
