Accidentally pulled the wires to the O2 Sensor help!
Old Jan 16, 2021 | 04:28 PM
cinikal's Avatar
Default Accidentally pulled the wires to the O2 Sensor help!
So I am an Idiot! I accidentally pulled the wires out of the connector that goes to the O2 sensor. It is a 2005 Accord EX 2.4l. Does anyone have a wiring diagram for this part of the system. Any help would be greatly appreciated!
Old Jan 16, 2021 | 11:01 PM
Sorry no schematics.
However, look at the wires.
Should have two wires that are the same color
Either two white wires or two black wires They go to the heater.
Ohm meter on O2 sensor will tell you which ones are the heater circuit.
Can read anywhere between 2 to 16 ohms depending upon the sensor.
The other two wires are for the O2 sensor.
When heated, they produce voltage between 0 to 1 volt.
Don't know if that can help you.
Good luck
Pannster
May 8, 2020 09:33 AM
jetvette
Jan 24, 2020 07:43 PM
v.l.prewett
Jun 23, 2018 12:29 PM
Raptor94
Jan 4, 2014 08:54 PM
ajaybali
Mar 29, 2010 11:31 AM
