any sudgestions????
Old Nov 25, 2008 | 08:00 AM
sybe3ice's Avatar
Default any sudgestions????
does the abs lights always lights on my gauge?
Old Nov 26, 2008 | 03:47 AM
Default RE: any sudgestions????
welcome to the forum, the abs light should go off after a scan when you turn your key on.If it stays on after your start, there is a problem with the abs system. Is your car under warranty? if so the dealer should fix it for no charge. If not under warranty, easy check is the brake fluid level, then for leaks at each individual brake unit, then for wear on the pads or linings. Also for debri in or around the brake area.
vtec_crx89
Nov 2, 2009 04:21 PM
honda parts
Dec 9, 2007 06:14 PM
jayson8826
Dec 28, 2006 02:42 AM
hondadude
Oct 20, 2006 06:28 PM
SLEEPER
Aug 5, 2006 03:01 PM
