Battery light on
Old Jan 8, 2026 | 10:18 PM
Ajs's Avatar
Ajs
Default Battery light on
I have a 2005 Honda accord it stopped running so I changed the starter thinking that was it. The battery was newer but I tested it and it was good as well. It turns out it was an issues with the key fob. Once I started using one of my old keys I was able to start it but then the battery light started coming on. I changed the alternator in hopes that was all it was. It still turns on and the alternator isnt charging the battery. I had it bench tested and it passed. I also in that time span had someone remove the aftermarket security system. I have checked most all of the fuses and that doesn’t seem to be the issue. I’m going through and making sure there isn’t a broken wire from when the person removed the security system. Anyone had any similar issues as to why it is not charging?
Old Jan 9, 2026 | 03:40 PM
We like numbers. What were the results of the battery CCA?
Mashal
Apr 25, 2025 07:14 AM
barbaranna
Jul 10, 2023 07:21 AM
de_loneguy
Apr 22, 2009 04:37 AM
dukevt
Mar 28, 2009 05:42 PM
