Changed 2006 Odyssey battery and now
Old Jan 30, 2024 | 07:05 PM
Mostrenga's Avatar
Default Changed 2006 Odyssey battery and now
I have a 2006 Odyssey that I changed the battery on last week, now none of my power windows work, I've checked both 7.5 amp fuses that provide power to the 4 20A fuses for each window, replaced the window relay. How can I get my windows operational again, any advice is greatly appreciated.
Old Jan 30, 2024 | 07:44 PM
Operation CHARM: Car repair manuals for everyone.
Home >> Honda Truck >> 2006 >> Odyssey V6-3.5L >> Repair and Diagnosis >> Windows and Glass >> Windows >> Diagrams >> Electrical Diagrams >> Power Windows Circuit Diagram
Power Windows - Circuit Diagram Part 1:
Power Windows - Circuit Diagram Part 2:
Power Windows - Circuit Diagram Part 3:
pro multis · About Operation CHARM
Old Jan 31, 2024 | 04:29 PM
Mostrenga's Avatar
Default Windows not working
Thanks for the schematics, but I'm not really able to understand them, can anyone tell me what to check next?
Old Jan 31, 2024 | 05:58 PM
Did you check the 20A #26 fuse between the relay and the window?
Old Jan 31, 2024 | 08:40 PM
Mostrenga's Avatar
Is that one of the 4 20A fuses together one for each window? If so yes.
Old Jan 31, 2024 | 08:51 PM
Mostrenga's Avatar
Default #26 fuse
I see now where #26 is, will check it tomorrow, thanks for the suggestion
Old Feb 1, 2024 | 04:27 PM
Mostrenga's Avatar
Default Not number 26
Not sure what's left that I can check.
Old Feb 1, 2024 | 05:21 PM
So you have 12 volts there and the fuse is good. If there are 12 volts there then the module should work. I would load test the ground circuit. A good scan tool would show the module inputs.
Old Feb 4, 2024 | 12:01 PM
Mostrenga's Avatar
Default Ground?
Could this be the main ground?, part of what started the problem was when I discovered that the ground clamp on the battery was not tight and can't be tightened more. Which caused the battery to drain several times resulting in the battery to no longer hold a charge. This is why I changed the battery, right now I have a nail that allows the clamp to be tight and will be putting a new clamp on, today it didn't have enough power to crank it again.
cot266
Aug 1, 2021 03:12 PM
Djcoons1
Jun 30, 2020 04:15 PM
ObCR-V
Apr 20, 2013 10:55 AM
aaronj
8
Mar 28, 2013 11:39 AM
dkm2
Oct 31, 2011 06:21 AM
