check engine light is on:
Old Feb 6, 2011 | 05:00 PM
rad384's Avatar
Default check engine light is on:
the check engine light is on on my 1999 honda accord v6, the error code says it has to do with the fuel system evaporating system, I guess there's a filter that has to be replaced some where, just don't know where or how, can anyone help.
Thanks
Old Feb 7, 2011 | 10:31 AM
Well, there's 2 different codes for the EVAP system. Either one means that it's respective part of the fuel evaporative emmission system isn't airtight like it should be.
P1456 = EVAP leak - fuel tank system (includes a bad gas cap)
P1457 = EVAP leak - control canister system
These can also be triggered by bad solenoid valves (common) or leaking vacuum hoses (easy to check) or problems in the sensors that measure this system.
Start with which code you got.
Old Feb 7, 2011 | 08:18 PM
rad384's Avatar
Thanks for the reply, it was a great help.
Old Feb 8, 2011 | 10:26 AM
Glad we could help you.
fyah17
Dec 22, 2012 03:03 PM
samuel_gatech
Nov 4, 2009 04:46 AM
silverbullet
Feb 19, 2007 08:26 PM
cpatd
Nov 13, 2006 02:03 PM
whermanov
Sep 23, 2006 04:16 PM
