dead engine?? help
Old Sep 25, 2006 | 03:34 AM
savang's Avatar
Default dead engine?? help
hey guys.. so i have a 95 civic ex sohc vtec.. and theres something wrong with the car? i need help if anyone knows what the problem may be.. heres the issue, the car starts fine, and runs normal, but only when the engine is cold.. once it starts getting warm, for example the temp gauge goes to about half way, then the engine dies right a way.. after it dies, it wont start.. i tried swtiching the map sensor, and will probably try the throttle body, but does anyone know what the problem may be?
Old Sep 29, 2006 | 11:00 AM
lana's Avatar
Default RE: dead engine?? help
If it happens when your radiator fan turns on, it might be:
1) throttle body - as you said; injection in general
2) check the batery charging using multimeter - both in steady (no additional consumers) and active (turn on the lights) mode. If you get arround 14 in steady and much lower in active (under 8), you should change the charger (sorry, I'm not native English speaker, so I can't remember the name of the device in englesh) or at least its coil. It worked for me
Hope you'll fix it soon
Lana
Old Oct 3, 2006 | 02:41 AM
wheelieboy20's Avatar
hey did you look at the blink codes on the ecm. i think ur vehicle has it
Old Nov 20, 2006 | 01:23 AM
DiRty96's Avatar
its a generator or alternator.
Pull your codes then post em up.
artful_artichoke
Feb 4, 2010 09:05 PM
splat41
May 26, 2008 11:11 PM
driverax
Dec 9, 2007 06:31 PM
bdjh
Sep 1, 2007 04:52 PM
30mpg
Apr 25, 2007 03:02 AM
