Did I blow my head gasket or is it something else?
Old Nov 7, 2011 | 09:16 PM
chrisearl092's Avatar
Default Did I blow my head gasket or is it something else?
91 CRX 1.5L
Saturday while driving home from work I was going up a really big hill, tachnically a mountain, and my car started sputtering. Didn't over heat or anything was just acting weird. The next day it wouldnt start. I thought maybe it was bad gas because I used a different station than usual. Got some gas cleaner and let it sit. Next day it fired right up, but there was white smoke coming from the exaust. I checked the oil and noticed it was high, so I changed the oil and filter with the right amount of oil. No smoke! Everything seemed fine, drove it around the block after idling for 20 min. Seemed to work great. About an hour later I took it for a test drive and after about a mile it was overheating. The temp shot all the way up very quick. I got it home and checked the coolant... Didn't lose any, and didn't see oil in it. Also checked the dipstick and didn't see any coolant/ water in the oil. I can't tell if it is a blown head gasket, opr something else that's causing it to over heat... Any help out there???
Old Nov 8, 2011 | 09:35 AM
Welcome to the forum,those are sure signs of a blown head gasket,did you hear any noise like a ticking sound coming from the motor at idle? Is it still blowing white smoke? The coolant in the oil will be a yellow color and kind of a foam.
Do a compression test to give you some idea. Don't confuse low compression for a bad head gasket, though. A bad valve can lower compression. And a bad ring.
Old Nov 8, 2011 | 09:08 PM
Well, I started it again today, let it idle for about 15 min and took it for a 5 mile drive. It started right up, got to normal temp and drove great. I thought maybe it was good. I decided to take it back out just to make sure, but when I started it, there was white smoke coming from the exaust again and wouldn't idle right so i just shut it off. pretty confused to why it would start right up and run great, then if i let it sit for an hour it starts up like a completely different car?
Old Nov 15, 2011 | 08:46 AM
You may be able to get the head shaved put on a new gasket and maybe OK.
89hondacrx
Dec 23, 2009 07:22 PM
209xintegra
Dec 9, 2009 02:24 PM
jmurphnd
Nov 28, 2009 02:38 PM
lofg0030
Aug 15, 2009 07:28 AM
mexxem2
Mar 25, 2008 10:45 AM
