front end sounds like a haunted house
hey guys am new to the forum and i have a ? i have this annoying noises coming from the front end, I have a 94 accord dx 4 door with 227xxx miles and its kind of rusting at the rear 1/4s above the wheels.......but its my car and its my source of independence ,soooo anyways midway thru the summer i starded hearing this dry sort of squeack and creack kind of like a haunted house door....and it got worse as time goes on ,it does it when i turn ,it does it when i go straight when i push up and down on the fender it doesnt do it till i push real hard it seens to be coming from the pass side but i dont know....cannot afford a mechanic since they are as pricey as doctors ,and am a student with a 15 hr a week job what can i do?
i was told to spray the moving parts under the car i.e bushings tie-rods sway-bar etc but am not sure that silicone or w-40 is any good cause they tend to remove the grease that is in the parts ....other than these i really like this bucket and for the milage its very dependeable....help!!!
thanks acmech i was under the car today and did alot of pushing and pulling on the rubber parts sprayed them with lithium also stuck the body up on jacks and turned the wheels back n forth and the steering joint sounds like the problem however i wouldnt even know where to start the work or what parts to order .....i dont want to change one thing and have the part next to it fail space was kind of tight under the car so looking at the large picture was inpossible,....is there a web-site that can show an exploted view of the mechanics of the steering?
RPM JEFF
Sep 24, 2012 03:13 PM
RPM JEFF
Sep 22, 2012 11:36 AM
hondaaccordsohcvtec
Mar 14, 2011 10:56 AM
AcuraPartisan
Nov 23, 2010 03:51 PM
aeli
Nov 14, 2010 05:59 PM
