Help!! 2001 Honda Accord EX
Help! I have a 2001 Honda Accord Ex that has been acting like &$it, When ever I press the gas to the floor or even half way to start to accelerate the engine sounds maybe like it’s getting no fuel. Then the car will buck back as if choking. Don’t know if it’s maybe ignition coils, weak fuel pump and or fuel injectors. The transmission seems to be fine so I don’t think it’s that. |
[QUOTE=Bdboy09;30412] Help! I have a 2001 Honda Accord Ex that has been acting like &$it, When ever I press the gas to the floor or even half way to start to accelerate the engine sounds maybe like it’s getting no fuel. Then the car will buck back as if choking. Don’t know if it’s maybe ignition coils, weak fuel pump and or fuel injectors. The transmission seems to be fine so I don’t think it’s that. ... I just took a video
Originally Posted by Bdboy09
(Post 30412)
(Post 30412)
Help! I have a 2001 Honda Accord Ex that has been acting like &$it, When ever I press the gas to the floor or even half way to start to accelerate the engine sounds maybe like it’s getting no fuel. Then the car will buck back as if choking. Don’t know if it’s maybe ignition coils, weak fuel pump and or fuel injectors. The transmission seems to be fine so I don’t think it’s that. ... I just took a video https://youtu.be/RUsRQ014g6E |
welcome to the forum. sounds like a fuel starvation/cutting out. if it were coil, it would be like a misfire or bad plug and consistant miss.
Check your fuel filter,it could be clogged,or when you cut your car off listen toward the rear of the car to see if the fuel pump makes any noise,it should.if not that could be the problem ,does it idle rough too? Another thing possible fuel pressure regulator. |
