Help!! 2001 Honda Accord EX
Old Jun 7, 2018 | 12:20 PM
Bdboy09's Avatar
Default Help!! 2001 Honda Accord EX
Help! I have a 2001 Honda Accord Ex that has been acting like &$it, When ever I press the gas to the floor or even half way to start to accelerate the engine sounds maybe like it’s getting no fuel. Then the car will buck back as if choking. Don’t know if it’s maybe ignition coils, weak fuel pump and or fuel injectors. The transmission seems to be fine so I don’t think it’s that.
Old Jun 7, 2018 | 12:24 PM
Bdboy09's Avatar
[QUOTE=Bdboy09;30412]
... I just took a video
Old Jun 7, 2018 | 12:31 PM
Bdboy09's Avatar
[quote=Bdboy09;30413]
... I just took a video https://youtu.be/RUsRQ014g6E
this video does more justice, mind you my foot is all the way on the gas the whole time
Old Jun 8, 2018 | 03:16 AM
welcome to the forum. sounds like a fuel starvation/cutting out. if it were coil, it would be like a misfire or bad plug and consistant miss.
Old Jun 10, 2018 | 09:46 AM
Check your fuel filter,it could be clogged,or when you cut your car off listen toward the rear of the car to see if the fuel pump makes any noise,it should.if not that could be the problem ,does it idle rough too? Another thing possible fuel pressure regulator.
Jessica Sanchez
Apr 10, 2018 08:58 PM
dries
Aug 17, 2017 10:44 AM
CHENAN
Aug 5, 2010 05:33 AM
sathya
Jun 6, 2010 10:28 AM
gordon
Jul 30, 2009 02:38 AM
