HELP with my 08 honda civic
Old Nov 15, 2015 | 05:16 PM
Kristen Courville's Avatar
Unhappy HELP with my 08 honda civic
couple weeks ago my car was getting little hot like little past the boat so my father thought lets put sealant in to close all the leaks because someone told him it might be a blown head gasket but every day i always have to fill it with coolant so yesterday i was driving on the free way slow lane and all of sudden my car when all the way to the H and then started making a clunking sound so i pulled over let it cool down for a bit and then i turn it on just where it shows all the light and it was down again whats going on with my car??? i just need someone not to give me the run around because i got a pressure test done and they said it could be a blown head gasket or cracked head well i found out i have a recall for my car on a cracked head i took it to a Honda dealer and they said no its not a cracked head so can someone please tell me whats going on with my car???
Old Nov 18, 2015 | 06:55 AM
welcome to the forum. Did the dealer do a compression check? what was said of the head gasket. under normal conditions, when the engine is overheated "H" or into the red zone for a while, the head gets warped and the head gaskets leaks.
Old Nov 18, 2015 | 10:25 AM
im not sure they gave me a paper saying whats wrong with it and also told me that it was the headgasket but its leaking from the back some people say it the hose idk but it does over heat now all the way to the h now becfore it did it would go past a little from the little boat i call it lol
Old Nov 19, 2015 | 06:01 AM
it is a little expensive to have the head gasket replaced, and have the head shaved/milled. it also is a good time to have the head checked for possible cracks, you can see the inside where normally it is unseeable with out a boroscope.
Old Nov 19, 2015 | 10:25 AM
theres no milkey stuff in the oil cap
Old Nov 20, 2015 | 05:04 AM
that is good, no water leak into the oil. water into the cylinders and burning it up, this would show as a steam like mist out of the tail pipe when it should be clear.
Old Nov 21, 2015 | 08:21 PM
lowlife9's Avatar
try purging the cooling system of air see if that helps also make sure the radiator cap is functioning properly.
