Integra won’t crank
Old Aug 22, 2018 | 11:35 PM
Infamousteg97's Avatar
Default Integra won’t crank
I have a freshly rebuilt lsv with a gsr head. It was running fine before I took it was rebuilt, I went from an rs shell to a gsr shell. I haven’t been able to make it crank but it has power all the way around, does anyone know that my problem could be? (Sorry if I put this in the wrong section I’m new) if you people need me to be more specific let me know and I’ll try to answer thanks
Old Aug 23, 2018 | 12:48 PM
welcome to the forum. did you check to see that you have clean terminals. check to see if you can turn the crank counter clockwise.
Old Nov 1, 2018 | 06:26 PM
Check to see if engine turns by manually cranking it
If it cranks then check voltage at starter
And also check to make sure there is a ground path for the engine back to battery
Dougie23
Mar 28, 2015 06:58 AM
kfresh28
Apr 10, 2011 04:12 AM
theboyssi16
Oct 23, 2009 08:44 AM
Bruster
Aug 19, 2006 04:26 PM
